Spark Plugs at 30k
Old Jan 14, 2007 | 04:26 AM
HEMI_n_Cali's Avatar
HEMI_n_Cali
Default Spark Plugs at 30k
Ive been reading some about what type of plugs i need to buy/use for my hemi. (04QCHemi) and i guess i was under the usumption that the origional spark plugs are suppose to last 100,000 miles before you need to change them. But i read i need to change them at 30K? Are they just break in plugs? What gives?
Old Jan 14, 2007 | 04:59 AM
claydawg's Avatar
claydawg
Default RE: Spark Plugs at 30k
No, they aren't break-in plugs. It appears the Hemi's don't like platinum plugs. Some say the platinum plugs can cause a drop in fuel mileage and misfiring, copper plugs seem to be how to go. Others say they run platinums and don't have a problem. This thread should help answer your question: https://dodgeforum.com/m_661636/tm.htm
Old Jan 14, 2007 | 03:38 PM
Powerslave's Avatar
Powerslave
I have ran the Autolite Platinum plugs in three trucks with no problems .
More than likely the reason the factory uses copper plugs is cost.
You do the math . Thats a lot of savings just by using standard plugs.
Then add in the fact you have shorter maintenance intervals and you are set.
