low beam out but high beam ok
Old Jan 24, 2007 | 12:04 AM
eds2003ram's Avatar
eds2003ram
Default low beam out but high beam ok
has any one had this problem. My passenger side headlight bulb just went out , but when the high beams are lit they are working on both sides. Before I get into checking this out , Has anyone had this happen to them and is it just the bulb that is out only on low? I'll check it out in the morn but just wanted to see if this actually happens with these type of bulbs.
Old Jan 24, 2007 | 12:09 AM
loiler921's Avatar
loiler921
Default RE: low beam out but high beam ok
fuse, relay
Old Jan 24, 2007 | 12:13 AM
eds2003ram's Avatar
eds2003ram
it only happens on low and on the passengers side . if it were the relay , I think it would go out on both sides.
Old Jan 24, 2007 | 12:35 AM
stump_breaker's Avatar
stump_breaker
Just replace the bulb. They still have 2 individual filaments and yes, one can go out while the other works. Or if you think it's something else, put the working bulb on the non-working side and see if it stilllights up.
Old Jan 24, 2007 | 01:06 AM
eds2003ram's Avatar
eds2003ram
yea , that is what I'll be doing tommorow. Let's see what happens, I'll let you all know.
Old Jan 24, 2007 | 01:14 AM
MoparMJM's Avatar
MoparMJM
ORIGINAL: stump_breaker
x2
Old Jan 24, 2007 | 04:31 AM
eds2003ram's Avatar
eds2003ram
just replaced the bulb in 20 degree weather. I couln't feel my fingers swaping the drivers side. It was the bulb and ofcourse it had to be the more expensive brite whight sylvanias that burnt out. thanks guys
