annoying wiper blades
Old Jan 25, 2007 | 02:58 PM
coolbreeze's Avatar
coolbreeze
Default annoying wiper blades
can anyone tell me if there is a fix for 2006 RAM 1500 wiper blades. it just might be me but i find it annoying that i can not see my hood center line as i drive because the wipers when off do not set low enough to get out of your line of sight to see the hood lines. for me it is how i center my vehicle while driving. is there after market wipers that can be installed that are bent enough to lower the position of the wiper when off. i do not understand why dodge hasn't engineered them to go lower because they sit a good 4 to 5 inches from the hood. any way any ideas would be appreciated.
Old Jan 25, 2007 | 05:07 PM
Foiled's Avatar
Foiled
Default RE: annoying wiper blades
Take them off and adjust them. You can normally just unbolt them and rotate them. But you will change the sweep of the arm. If you lower them the arms will not go as far to the left.
I did this on my avenger because the arms were too high like you are complaining about. I am not sure but the Ram should have similar arms.
