Sirius Direct Connect Install
Old Feb 14, 2007 | 03:06 AM
cr80renob's Avatar
cr80renob
Default Sirius Direct Connect Install
I just purchased the "Professional Vehicle Install Kit (SIR-PVK1)" to directly connect my Sirius Stiletto 100 to my head unit. Has anyone ever done this before? I don't have the slightest clue of where to attach the power supply (one wire with a fuse). Does anyone have any ideas? Any help would be greatly appreciated!
Old Feb 14, 2007 | 05:25 AM
djr04's Avatar
djr04
Default RE: Sirius Direct Connect Install
If it is a 12 volt source that is needed, tap into your cigarette lighter, that way it won't be on all the time, only when your truck has power to the radio and accessories.
Old Feb 14, 2007 | 10:12 PM
cr80renob's Avatar
cr80renob
What color is the wire I want to tap into?
Thanks,
Shane
Old Feb 17, 2007 | 03:19 AM
cr80renob's Avatar
cr80renob
What color is the wire I want to tap in to? I really want to finish this up soon!!! Thanks for your help
Shane
Old Feb 17, 2007 | 05:07 AM
lukeca's Avatar
lukeca
I tapped into the power going to the radio for my sirius.
Constant 12V+ is Pink/Yellow
Switched 12V+ is Red/White
Ground is Black
So if you want the sirius to stay on whether the vehicle is on or off use constant power, if you want it to go on and off with the key use the switched power.
Old Feb 18, 2007 | 02:55 PM
cr80renob's Avatar
cr80renob
Thanks a lot for your help!!
