07 2500 hemi 6spd -vs- 1500 hemi automatic
My 06 2500 ram 5.7 reg cab 4x4 has the six sp manual... If your looking for all out tire smoking drag racing the automatic is faster....
The 6sp is like driving a school bus, it is geared low to get the max amount of power from the hemi, it has all the awsome power, not a lot of speed...
On the high way in 6th, thier's a awsome amount of accleration once you have worked threw the gears, The 6sp manual is not a performance inspired design, its built as a heavy duty truck transmisson.
I don't want to convince any one that a 5.7 6sp is slow, it's quite quick for a 3/4 ton truck and I like shifting my on gears...and I will never go back to automatic...
Acceleration and towing are better in a automatic because the trans fluid takes the abuse, not the clutch...It's driver preferance..
Exactly what I say abauot the manual. On hands total control of the engine is what I'm looking for . It won't replace my 93 RX , but somewhat remind me of the good old days, downshifting from 80mph into a 180 degree off-ramp and snuging the curve without having to brake to much. I know I can't have what I use to with the sports car but I think the 6 speed is the way to go to have more control of this 5k beast in all those situations.
When it comes time to overhaul my engine and trans, I plan on replacing the 545-RFE with the G56 manual. I'm pretty sure it can be done withoutmuch specialized work. I'm hoping it is as simple as to replace the 5-45RFE and associated PCM with the G56 and associated PCM. Might need a new drive shaft but that is about all I can think of.
thiers a little more to it...the rear axle on the 2500 is not the same as a 1500, I doubt the 2500 drive shaft is the same as a 1500, so somewhere in this process a ring and pinion may need to be swapped out.
Thier are two versions of the getrag 6 sp transmisson in the 2500, I don't have the G56 in mine, But I'm sure the 4.7 6 sp uses one of the getrag transmissons that is in the 2500..
