hemi 0-60 time
Old Feb 23, 2007 | 04:06 AM
ttuguy1983's Avatar
ttuguy1983
Default hemi 0-60 time
ive read that a stock hemi rc will hit 60 somewhere in the mid 6s range. has anyone achieved this?
Old Feb 23, 2007 | 11:47 AM
DelawareDon's Avatar
DelawareDon
Default RE: hemi 0-60 time
Almost all the articles I have read on Hemi Ram 0-60 times, as posted by professional "testers" with electronic timing equipment, seem to reveal times in the low 7 second range.Some have indicated a 0-60 time as highas the low 9 seconds. What you get will be dependent upon, to a large degree, what type of Ram you are running. 2 door stock cab vs. quad cab vs. mega cab? 2 wheel drive vs. 4 wheel drive? Any time below 7 seconds is pretty unusual.
Old Feb 23, 2007 | 11:53 AM
BigNelly07's Avatar
BigNelly07
also, any time you are trying to achieve the quickest time in a vehicle, it ALL depends on available traction. Like Don said, weight plays a big factor as its easier to get 4500lbs to 60 than it is to get 6000lbs. Even with the best electronic equipment, if traction isnt there, then time suffers.
A number of other factors effect acceleration but to make a simple question to your simple answer, to achieve 0-60 in 6.5 seconds with 345hp and using a 3.92 gear would need to be done in a standard cab 2WD with -0- wheelspin. I am talking not even so much as a squeak out of the rear tires. A WOT launch on a drag radial would achieve this.
But, right from the showroom floor, your looking at low to mid 7's.
Old Feb 23, 2007 | 12:09 PM
ttuguy1983's Avatar
ttuguy1983
ok thanks. i have been hitting low to mid sevens. i thought maybe my truck was running week. lol.
Old Feb 23, 2007 | 12:15 PM
BigNelly07's Avatar
BigNelly07
nope, it dont sound weak. But a better test might be 20-80 instead of 0-60. That way there is no traction deficit.
Old Feb 23, 2007 | 12:24 PM
ttuguy1983's Avatar
ttuguy1983
whats the 20-80 time one an rc hemi?
Old Feb 23, 2007 | 12:56 PM
BigNelly07's Avatar
BigNelly07
dunno, but on the way home I can tell you what it is in a QC 4x4 Hemi. :-)
