throwing codes
Old Mar 2, 2007 | 02:43 AM
dowale41's Avatar
dowale41
Junior Member
Default throwing codes
My friend told me about the trick when u have a check engine light on and i do, so u turn the key onto accessories 3 times then a code comes up on the odometer, i was wondering if anyone knows the codes p0113 i would appreicate anything thank you...
Old Mar 2, 2007 | 10:10 AM
big guy's Avatar
big guy
Default RE: throwing codes
P0113 Intake Air Temperature (IAT) Senser Circuit High Voltage.
Old Mar 2, 2007 | 06:53 PM
dowale41's Avatar
dowale41
Junior Member
thank you.. what would you recomend to do take it to the dealership and reset it? cuz i looked at everything and it all is connected.
Old Mar 3, 2007 | 10:35 AM
big guy's Avatar
big guy
Could be the IAT/ MAP senser? But who knows! It is located on the top of the intake manifold. Make sure it is plugged in good. You could try resetting the computer. Not much choice anymore. You probally going to need the services of the dealer. If somebody would post they had the same code setand what sensor actually corrected the problem. I would be inclinded to try that. Still no guarantees.
Good Luck.
