leveling my 03 2wd ram
Old Mar 16, 2007 | 11:23 PM
m.lee.43770's Avatar
m.lee.43770
Default leveling my 03 2wd ram
Im wanting to level out my 1500 2wd,but im not sure how many inches to go. Im guessing I should go with the 1.5" coil spring spacer but they also have the 1" and 2" spacers but im not sure which of the three would make my truck be the most level. Does anyone have any suggestions and has anyone put a leveling kit on their 2wd truck?
Old Mar 17, 2007 | 01:00 AM
DeWalt378G's Avatar
DeWalt378G
Default RE: leveling my 03 2wd ram
I don't have a 2wd, but this is what some of my buddies and I did in the past.
Park on aflat/level surface. Measure from the ground up to the top center most point of your front wheel well right at the lip and record this number. Jack the front end up a little at a time and stand back to see where you like it to be. Make sure you jack evenly. Measure again EXACTLY the same way as before. Take this new meausurement and subtract the previous. This number should be the appoximate lift you need. Pick the leveler closest to this measurement, but not more. Your truck should be pretty close to level.
Old Mar 17, 2007 | 02:18 AM
m.lee.43770
thanks dewalt i'll try that
