Ashtray won't stay closed......
Old Mar 25, 2007 | 04:58 PM
QuadzillaStyle's Avatar
QuadzillaStyle
Default Ashtray won't stay closed......
It doesn't look very complicated so why won't it stay latched. Should I take it all the way out (downward force to pop out) to see if there is chainge behind/under it? That is all I put in there is change.
TP
Old Mar 25, 2007 | 09:40 PM
ce2flaco's Avatar
ce2flaco
Default RE: Ashtray won't stay closed......
I use mine for change as well and when a couple coins get underneath it never wants to close. Works fine after i remove them. Also if you have alot of change the weight will make it open as well.
