04 Ram burning antifreeze!!!!!!
Old Mar 26, 2007 | 12:45 AM
CHIWS6's Avatar
CHIWS6
Default 04 Ram burning antifreeze!!!!!!
is there any1 that is haveing the same problem? where can i get the head gasket and bolts? is there a website that shows pics and description on how to replace the head gaskets? any info would be helpfull fellas, thanks
Old Mar 26, 2007 | 12:46 AM
BgBluRam's Avatar
BgBluRam
Default RE: 04 Ram burning antifreeze!!!!!!
Hemi or 4.7L???
Old Mar 26, 2007 | 01:04 AM
CHIWS6's Avatar
CHIWS6
its a 4.7L
Old Mar 26, 2007 | 02:08 AM
djr04's Avatar
djr04
If by burning antifreeze you mean antifreeze is leaking into your engine, you want to get that taken care of asap. I had a blazer with a bad intake gasket that caused that problem, exhaust had a sweet smell to it. If you let it go too long, you could end up with antifreeze in your oil, which will change it to a cappucino color. This is very very bad for the engine.
Old Mar 26, 2007 | 02:16 AM
BgBluRam's Avatar
BgBluRam
May bea blown head gasket. you may also want to check that the heads are not warped. You can get the gaskets at any Auto parts store, dealership, or performance shop. Good luck, I hope it is only the gasket.
Old Mar 26, 2007 | 03:21 AM
Dodge Tech's Avatar
Dodge Tech
do u know if u have 7/70 power train warranty??
if u dont know i can go onto chrslers site and look up your vin I will need the last 8 and mileage
