p 0113
Old Jul 25, 2008 | 03:10 PM
irelandshemi's Avatar
irelandshemi
Default p 0113
so i cleaned my throttle body the other day hooked the sensors back up and started it and the check engine light came on so i fiqured maybe it jsut has to be driven for a little bit but its still on after two days and im getting a p0113 reading
which i guess is P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
any ideas how to get it to go away, is it bad if i just erase the code and dont fix it or what
Old Jul 25, 2008 | 10:13 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: p 0113
Did you unplug the connector to the sensor and ck for a bent pin? With voltage high code, your controller is seeing 5 volts instead of maybe 2.5 volts.
