Voltage Gauge running High...HELP!
Old Jan 21, 2009 | 12:57 AM
mattchiro's Avatar
mattchiro
Default Voltage Gauge running High...HELP!
I own a 2003 Dodge Ram and my voltage gauge has been running higher than normal and the lights dim when I turn on the Heat/AC. Can this be a bad alternator?
Also, I got a "no bus" error code in the odometer.
Old Jan 21, 2009 | 11:02 AM
John  M's Avatar
John M
Any auto parts store can do a quick free test to see if it's the battery or alternator that's going out on you.
I don't know what it'd have to do with the odometer / data bus though.
Old Jan 21, 2009 | 11:08 AM
osufans's Avatar
osufans
it could possibly be dropping the voltage too low, which is affecting the PCM. just throwin' that out there....
Old Jan 21, 2009 | 11:15 AM
dirtydog's Avatar
dirtydog
Moderate User
It sounds likr your voltage regulator is going bad. That's an internal alternator part. That can cause overcharging, undercharging...etc...
Old Jan 21, 2009 | 01:39 PM
mattchiro's Avatar
mattchiro
Thanks for the help all. On my way to the auto parts store....will let you know what happened.
Old Jan 21, 2009 | 03:50 PM
dirtydog's Avatar
dirtydog
Moderate User
How did you make out? I seen an almost new alternator for $75 on ebay. They say it's a new pull off for a customer that upgraded. Lemme know and I'll find it if interested
Old Jan 21, 2009 | 03:58 PM
mattchiro's Avatar
mattchiro
Had the battery tested at an auto shop and they said its going bad. I swapped it out this morning and the gauge is still reading a little higher than normal.
I used my hypertech programmer to find error code P1687 which indicates that I have a faulty instrument panel or bad module. Could that cause the voltage gauge to read a little high?
Old Jan 21, 2009 | 04:17 PM
dirtydog's Avatar
dirtydog
Moderate User
I would think that other guages would be effected as well??
Old Jan 21, 2009 | 04:39 PM
mattchiro's Avatar
mattchiro
Before I take the truck to the dealer and spend 100 bucks on finding out if I have a faulty instrument panel...is there anything I can find on my own? Which fuses could be bad?
Old Jan 21, 2009 | 05:16 PM
dodgeorgethit's Avatar
dodgeorgethit
Check battery connections
