help! throwing all sorts of codes!
Old 01-28-2009, 07:49 AM
madsn11's Avatar
madsn11
madsn11 is offline
Default help! throwing all sorts of codes!
the other day my truck went crazy. crazy idle lightning bolt dash light flashing,and lost all power. i have had a p0441 code nowhave 2106 2118 and 2110 any guesses on what it could be? HELP!
Old 01-28-2009, 08:59 AM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Well the 0441 is evaporator system, but the others I believe are throttle control.
Check the entire evaporator system, especially around the cannister for leaks. Reset the throttle control and if that doesn't work change the position sensor...
Old 01-28-2009, 04:46 PM
madsn11's Avatar
madsn11
madsn11 is offline
is the canister right underneith the back seat on the 03 quad cab? and how do i reset the throttle control?
Old 01-28-2009, 05:08 PM
HammerZ71's Avatar
HammerZ71
underneath, looks like this:
The 0441 is a "small" or minor leak, by chance, check the damn gas cap too. Cracked hose from the pump to the charcoal filter is very common. Should NOT be enough for a power loss, that's going to be the TPS system. Do a search, somebody gave a step by step reset in this section not long ago.
If you find you gotta replace the sensor, it's a relative cheap part and a 10 minute unplug/plug fix...
Quick Reply: help! throwing all sorts of codes!
