Need some help with the e-fan wiring..
Old Feb 19, 2010 | 08:14 PM
cheapbeater's Avatar
cheapbeater
Default Need some help with the e-fan wiring..
Hey guys, awile back i got a taurus efan from a guy locally and i finally got the controller. I want it to run on low at all times but i want to have a bypass switch to turn it on high if needed... AF hemi sent me his wiring diagram (he has his switched to run on high like i want) but the relay he used isnt the exact same as mine and i am too dam retarded to figure it out...
The instructions say orange wire goes to fan +, blue goes to a second fan if needed (both come out of same hole), red goes to battery, brown goes to temp sensor, yellow goes from ig. source to probe, black is ground and the middle port (87a) is open, the small green wire can be used as a bypass but its tiney... way to small to run the fan on high.
I'm confused as hell, i know i can get it to run on low, but how do i wire it to run on high with the flip of a switch? can i use that middle hole (87a)? or should i just run a switch bypassing everything and just connecting the battery to the fan directly and put a switch in line?
i'd like to get everything set up before i go to put it in, any help would be appreciated, i can get more pics..
I feel so fukken dumb... no one else seems to have issues with the wiring, but i am a tard when it comes to wiring. PLEESE HELP
heres what i got:
Old Feb 19, 2010 | 09:52 PM
SMKNRAM's Avatar
SMKNRAM
whoa man!! those pics are messing with pickled brain!!! I need another drink!!! I am wiring mine up this weekend, so I might be able to help you then! but not right now, that is way to confusing....
Old Feb 19, 2010 | 11:40 PM
davb673's Avatar
davb673
cheapbeater,
I did my install a few months back, and did take some pix and writeup my install. However, I am not able to post it here for some reason. I did label one picture where I wired up my relay. Hopefully this will help you out. If you like, PM me your email and I'll send you my howto and see if that helps you any...
Well nuts, it seems I am at my max for pictures. Tell you what, I will post a couple in my gallery and see if that helps you. Gotta love 'pooters.
Old Feb 19, 2010 | 11:53 PM
cheapbeater
davb, let me know when you get those pics up. you can pm them to me too. thanks
