Efan Which wire is low?
Old Feb 24, 2010 | 12:57 PM
  #31
weedahoe's Avatar
weedahoe
Hall of Fame Member
orange......yellow.....orange.....yellow......
hell, they're close to one another anyway. Quit being lazy and just go hook it to the battery and see what you get. ;-)
Old Feb 24, 2010 | 01:29 PM
  #32
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ok ok ok.............
If you look closely in this pics you will see the brown and ORANGE being used.
http://public.bay.livefilestore.com/...g/102_1727.jpg
Old Feb 24, 2010 | 01:30 PM
  #33
SMKNRAM's Avatar
SMKNRAM
HA HA HA!! I think it is the orange..... no no wait yellow...... no no I think it is the one that WONT blow fuses, so the opposite of what you have!
Old Feb 24, 2010 | 03:48 PM
  #34
cheapbeater's Avatar
cheapbeater
CHIT!! now i gotta go change it!
and to think i nom'd frog for MOTM... (never voted tho)
thanks weed. you da MAN!
Old Feb 24, 2010 | 04:06 PM
  #35
weedahoe's Avatar
weedahoe
Hall of Fame Member
youre welcome bro. I just happened to have had that pic store online
Old Feb 24, 2010 | 04:11 PM
  #36
SMKNRAM's Avatar
SMKNRAM
good call! I figured it was on high, it took me 3 fuses to figure out I did not need a high speed fan!!!
Old Mar 1, 2010 | 11:19 PM
  #37
bigpappaholt's Avatar
bigpappaholt
did my efan this weekend.... i know some people have issues getting fan off... i rented this tool from auto zone and it worked wonderfully with a big monkey wrench, got it off first try.. its an AC clutch holder.
also whats a good temp to set controller at for stock stat?
Old Mar 1, 2010 | 11:46 PM
  #38
SilentRamAD's Avatar
SilentRamAD
+1, Because I haven't installed a 180* yet ~_~. And what would happen if you did set it lower than your stock t-stat, would it cause problems with it not engaging and opening ? Kid here still learning the ropes don't hang me
Also if Teach is keeping an eye on this thread. Apparently their controllers aren't the same as the one you got I'm assuming. And was wondering how yours is holding up with the supplied 30A fuse. Because if I need a larger one I'd rather get it now before I do the install this weekend hopefully.
Old Mar 2, 2010 | 07:56 AM
  #39
weedahoe's Avatar
weedahoe
Hall of Fame Member
my temp on my controller is set to about 200. I adjusted my temp all the way to the max and started the truck. Then used a temp laser gun to check the temp on the upper rad hose and when it got to 200 I lowered the adjustable switch on the controller until the fan came on. So mine is set somewhere around 200.
Old Mar 2, 2010 | 08:16 AM
  #40
SMKNRAM's Avatar
SMKNRAM
I have mine about the same I was shooting for 190 ish, I dont have a temp gun, going by dash guage. But with factory t-stat I would set the temp about 200-210. just me
