mopar 4 inch lift with 37s
Old Apr 23, 2010 | 11:24 AM
  #51
blake8581's Avatar
blake8581
nonetheless, if you already have the lvl kit w/ 35's, your taking a huge chunk out of the quoted price, since you will be running your same tires..
im trying to decide if i want to go w/ 4'' or 6''
Old Apr 23, 2010 | 01:06 PM
  #52
cpelton's Avatar
cpelton
Originally Posted by Cap10crch
I believe it was that cheap for him because he found someone who had the 4 inch and wanted to go to a 6 so he got the used lift for very cheap and then did the install himself.
yup! Lucky on my part. Also keep in mind that a shop is going to charge around $1000 for the install, its not hard to do on your own if you have the time and access to a lift.
Old Apr 23, 2010 | 01:10 PM
  #53
blake8581's Avatar
blake8581
Originally Posted by cpelton
bingo! Lucky on my part. Also keep in mind that a shop is going to charge around $1000 for the install, its not hard to do on your own if you have the time and access to a lift.
ive been meaning to PM you, but whatever..
1. if you could do it all over again, would you still have gone with the 4'' or 6''
2. what spacers do you need to run the OEM 20'' Wheels for that lift?
Thanks in advance-
Blake
Old Apr 23, 2010 | 01:42 PM
  #54
cpelton's Avatar
cpelton
I'd go 4" again for sure, I achieved the exact look I wanted with 35's. You will need 1/4" wheel spacers for the fronts to clear the aftermarket knuckle. I found mine on Ebay, try to stay away from the elcheapo cast ones as the metal can actually compress and cause your wheel to come loose, what you will want is a machined or billet spacer. I do a torque check every oil change and have not found them loose yet.
Here is a link to a set of 4:
http://www.sfxperformance.com/parts/GORSP603-X4.htm
Old Apr 23, 2010 | 05:26 PM
  #55
blake8581's Avatar
blake8581
thanks a million man, i have mine on order now.
i think im goign to do the 4'' as well.
before i even considered buying the '09, i came across your truck on doing a '09 lift pic' search on google image.. thats what brought me here, i think yours is the perfect set up.. thanks a million
Old Apr 23, 2010 | 09:13 PM
  #56
Busta1n2's Avatar
Busta1n2
Some great looking lifted trucks!
Old Apr 23, 2010 | 09:40 PM
  #57
Cap10crch's Avatar
Cap10crch
Are these the ones that you used? I'm guessing 5X5.5 is the size we need to get? It doesn't say that they are machined, how can you tell?
Old Apr 24, 2010 | 02:58 AM
  #58
cpelton's Avatar
cpelton
Not the specific ones I have, I found mine on ebay. It says there they are forged so they are machined out of a forged block of steel. Our wheel bolt pattern is 5x5.5.
Old Apr 24, 2010 | 08:13 AM
  #59
Cap10crch's Avatar
Cap10crch
Ok, I ordered them. I also order the 4 inch Mopar lift, found it for $1,965 on ebay. I found the same 4 inch Superlift for $1,899 so I got the Mopar name and the warranty/peice of mind for $66. I'm throwing on some BFG All Terrains 37X12.5R20. It will probably be 2-3 weeks till its all here and installed but I will make sure to put up some pictures when it's done.
Thanks for your help.
Old Apr 24, 2010 | 09:53 AM
  #60
mjake's Avatar
mjake
what wheels do you have? Also what is the exact size of your tires are they 37 12.50s or something different.
