Gas Mileage
Old Apr 4, 2011 | 08:32 PM
stump3r's Avatar
stump3r
Originally Posted by gutty96
Try it, but don't buy too much into it.
Something still seems fishy to me, I did the calcs, sure. With the #'s in the OP. However, I have used from 87-93 octane in the RAM since I bought it, just to see how they do. I didn't notice even 1mpg difference under normal driving, let alone 5mpg. 5mpg gain or loss for switching octanes doesn't seem right.
On there other hand, winter formula in the 87 vs straight formula for the 91 may make a 3-4mpg difference.
I personally think it warrants further investigation. My Dakota runs smoother on high octane but the mileage certainly doesn't jump enough to justify the added cost. Will be interesting to see if I can reproduce the same results with my Ram.
Old Apr 5, 2011 | 12:03 AM
Plainbroke's Avatar
Plainbroke
Cool Try it, but don't buy too much into it.
That may explain my change in mileage recently went to 91 octane and noticed about 3 mpg change on the overhead havent used the whole tank yet to see exact amount.
Old Apr 5, 2011 | 01:38 AM
eclipsems's Avatar
eclipsems
Agreed. 87 to 93 octanes have discernable difference in regards gas mileage.
Higher octane is largely used to run an engine that requires it such as boosted or high compression applications to help manage detonation. It’s never been used to increase mileage of a vehicle.
Don't take my word for it.
Read this:
http://www.truckblog.com/447-fuel_ec...s_fuel_economy
Old Apr 5, 2011 | 09:55 AM
09RuffRam's Avatar
09RuffRam
i would have to say i definitely notice a mpg difference between 87 and 91. usually a few mpg.
Old Apr 5, 2011 | 03:27 PM
CaptObvious75's Avatar
CaptObvious75
Are we checking the Ethanol content of each gas? I know that some regular unleaded in my area range from 10% Ethanol content for Regular, 5% for Mid-grade and most of the time 0% Ethanol for Premium. If Ethanol hurts MPG, then this could explain why.
Also, unsure if this has been stated before, but the Ram HEMI is designed for mid grade for its full output. If you put Regular in it, the timing retards and thus, less power is made. This is a heavy truck, so it will take more fuel and air at Regular octane because of the retarded timing vs if the truck was running on Mid-grade and has its full power output potential.
retarded timing+ higher ethanol= low gas mileage. We need to dyno the truck on Regular and then on Mid-grade to see the power difference... but i think this gas test the OP did may justify what i explained.
The 0 Ethanol content alone in 91 octane fuels might even make the MPG jump worth it vs Mid-grade's known 5% Ethanol content... food for thought Ram owners!
Old Apr 8, 2011 | 10:06 AM
huntergreen's Avatar
huntergreen
i'll have to check, but if this is true in new jersey, can using premium hurt the hemi?
Old Apr 8, 2011 | 12:27 PM
cmscat50's Avatar
cmscat50
I'd question the weather during that 3 week stretch. Going from winter temps to spring temps alone would make up the difference posted by the OP.
Old Apr 9, 2011 | 09:53 AM
gutty96's Avatar
gutty96
I did a trip to Toronto yesterday to pick my Dad up at the airport. I rarely switch my my #'s over to MPG from L/100kms, but I did, and this is what I was averaging on 87 octane. Sorry for the flash, didn't want to be playing with the phone too much on the highway.
Truthfully, I doubt I can do much better, even with higher octane, but I am going to try it when the price comes down a bit (if it does! LOL)
Old Apr 14, 2011 | 02:33 AM
metroworks's Avatar
metroworks
I try to drive try to drive very conservatively but I'm getting 14 mpg/ 16L/100kms. I switch from 87 to 89 octane & gas up a Esso or Chevron. I also drive about 100 kms or more per day so I with that I could get the numbers people claim.
Old Apr 14, 2011 | 08:12 PM
vette68's Avatar
vette68
I'm finding the Shell 89 is the best for milage so far, with consistantly getting over 700km per tank. I just installed a K&N filter (on sale for $65.00) in place of the factory filter and noticed more of an improvement on milage. Haven't finished this full tank yet, but look like the K&N filter will increase the milage by 20+ km per tank. I drive 70km one way to work each day, 140km round trip. Driving down to work, the average is 11.5, and coming home is 12.6. There is a small change in elevation from my house to Toronto.
