Spare Tire, check yours
Old Sep 28, 2012 | 09:51 AM
oldjeep's Avatar
oldjeep
Originally Posted by bwdakrt
Go ahead and try it and then report back as to how much it cost you to rebuild the rear diff. Different size tires will cause the rear axles to rotate at different speeds and that will really **** off the gears.
LMK how it comes out for you.
I've built plenty of rear ends and rebuilt plenty of lockers and LSD's. Which "gears" in an lsd do you think are going to get "pissed off"?
Old Oct 28, 2012 | 11:32 AM
RAMULAK's Avatar
RAMULAK
I just checked mine and it is a temporary 17" tire. And no way a 20" will fit in there. Too close to the pipes. Plus I can see oil from my diff flinging onto the gas tank now....Great.
Old Oct 28, 2012 | 09:05 PM
Cmerritt84's Avatar
Cmerritt84
A 20" full sized tire WILL fit in there. I have one in my spare rack.
Old Oct 29, 2012 | 08:04 AM
LU229's Avatar
LU229
CORRECT...!!! I did the same as well.
Old Nov 14, 2012 | 05:52 AM
Bigbody's Avatar
Bigbody
I may be wrong but I believe even though the rim is 17" the tire is taller to match the night of the 20" tires or pretty close to it, maybe someone should take their spare off and put it next to the stock 20 and see how much of a difference there is
Old Nov 14, 2012 | 03:27 PM
pavement_hater's Avatar
pavement_hater
I don't think your truck is even going to notice the difference.
Dimension Tire A: 275/60 R 20
(33 x 10.83 x 20) Tire B: 235/85 R 17
(33 x 9.25 x 17) Difference
Width
Sidewall height
Overall height
Circumference
10.83" (275.00mm)
6.50" (165.00mm)
32.99" (838.00mm)
103.65" (2632.65mm)
9.25" (235.00mm)
7.86" (199.75mm)
32.73" (831.30mm)
102.82" (2611.61mm)
-1.57" (-40.00mm)
+1.37" (+34.75mm)
-0.26" (-6.70mm)
-0.83" (-21.05mm)
