new rims in the future
Old Mar 25, 2013 | 09:56 PM
Nick Ladd's Avatar
Nick Ladd
Default new rims in the future
after doing some research i have my mind set on a set of 5 moto metal 951 rims, just have a few questions fist before i start shellin out some money as this will be my first rim swap ever
1. just to make sure the bolt pattern is 5 x 5.5 correct?
2. the max load per rim is 2200 lbs. seems a little low to me but what do i know
3. i assume that ill just be able to swap tires from rim to rim and be good to roll no?
link to rims for reference
http://www.4wheelparts.com/Wheels/MO...fPMO9517955312
Old Mar 25, 2013 | 10:15 PM
Cmerritt84's Avatar
Cmerritt84
You should be good. That max weight puts your truck at almost 9k pending each rim was loaded to the max. Your tires prolly are rated less than that.
Go for it.
Old Mar 25, 2013 | 10:38 PM
Nick Ladd's Avatar
Nick Ladd
well i was doing a little more research and the rims are 9" wide and the stock ones are only 7" i dont believe the stock wranglers are doing top be able to stretch that so they may have to wait till i get some new rubber GAHHH!!
Old Mar 25, 2013 | 10:42 PM
Cmerritt84's Avatar
Cmerritt84
You should be ok. Especially if you're on 20's. I believe stock chrome 17s are 17x8, the alloy 20s are 20x8 and the clads 20x9
Old Mar 26, 2013 | 10:11 PM
Nick Ladd's Avatar
Nick Ladd
mine are the 17" plain old aluminum wheels which i believe are 7" wide and the metals are 9" wide, guess ill have to use the spare tire as the test when i get the first rim
