Unlimited powertrain questions
Old Aug 9, 2013 | 02:16 PM
RGVram99's Avatar
RGVram99
Default Unlimited powertrain questions
I have a couple of questions about the unlimited powertrain warranty 5 year inspection. First, for those of us who have aftermarket bolt on's (CAI, headers, etc.), these parts "should" not affect the inspection pass/fail assessment right? Does anyone know what exactly is being inspected outside of obvious neglect and abuse? Lastly, I saw that the inspection has to be done 60 days before or after the in-service date, so is the in-service date the same as the date of purchase? Here is some warranty info I found online:
LIFETIME POWERTRAIN LIMITED WARRANTY
A. Who is Covered?
You are covered by the Lifetime Powertrain Limited Warranty if you are the first registered owner or lessee for use of the vehicle. Subsequent owners or
lessees, even if they are within the same family or business, are not covered. Successor business entities or persons to whom the vehicle is transferred by
operation of law are also not covered.
B. What’s Covered
The Lifetime Powertrain Limited Warranty covers the cost of all parts and labor needed to repair a powertrain component listed in section E below that is
defective in workmanship and materials. There is no coverage for towing in the event of disablement.
C. When It Begins
The Lifetime Powertrain Limited Warranty begins at the end of the Basic Limited Warranty.
D. Excluded Vehicles
SRT vehicles, Sprinter vehicles, diesel equipped vehicles, all Ram Cab/Chassis vehicles, rental vehicles and government vehicles are not covered. Vehicles
used as a police vehicle, taxi, limousine, postal delivery vehicle, or ambulance are not covered by the Lifetime Powertrain Limited Warranty.
E. Parts Covered
The Lifetime Powertrain Limited Warranty covers these parts and components of your vehicle’s powertrain supplied by Chrysler Motors LLC:
Gasoline Engine: cylinder block and all internal parts; cylinder head assemblies; timing case, timing chain, timing belt, gears and sprockets; vibration
damper; oil pump; water pump and housing; intake and exhaust manifolds; flywheel with starter ring gear; core plugs; valve covers; oil pan; turbocharger
housing and internal parts; turbocharger wastegate actuator; supercharger; serpentine belt tensioner; seals and gaskets for listed components only.
Transmission: transmission case and all internal parts; torque converter; drive/flex plate; transmission range switch; transmission control module; bell
housing; oil pan; seals and gaskets for listed components only. NOTE: MANUAL TRANSMISSION CLUTCH PARTS ARE NOT COVERED AT ANY
TIME.
Front Wheel Drive: transaxle case and all internal parts; axle shaft assemblies; constant velocity joints and boots; differential cover; oil pan; transaxle
speed sensors; transaxle solenoid assembly; PRNDL position switch; transaxle electronic controller; torque converter; seals and gaskets for listed
components only. NOTE: MANUAL TRANSMISSION CLUTCH PARTS ARE NOT COVERED AT ANY TIME.
All Wheel Drive (AWD): power transfer unit and all internal parts; viscous coupler; axle housing and all internal parts; constant velocity joints and boots;
driveshaft and axle shaft assemblies; differential carrier assembly and all internal parts; output ball bearing; output flange; end cover; overrunning clutch;
vacuum motor; torque tube; pinion spacer and shim, seals and gaskets for listed components only.
Rear Wheel Drive: rear axle housing and all internal parts; axle shafts; axle shaft bearings; drive shaft assemblies; drive shaft center bearings; universal
joints and yokes; seals and gaskets for listed components only.
Four-Wheel Drive (4X4): transfer case and all internal parts; transfer case control module and shift mode motor assembly; axle housing and all internal
parts; axle shafts; axle shaft bearings; drive shafts assemblies (front and rear); drive shaft center bearings; universal joints and yokes; disconnect housing
assembly; seals and gaskets for the listed components only.
F. When Lifetime Powertrain Limited Warranty Does Not Apply
You are not covered by the Lifetime Powertrain Limited Warranty if you are a second or subsequent owner of the vehicle.
G. Inspections
In order to maintain the Lifetime Powertrain Limited Warranty, the person or entity covered by this Powertrain Limited Warranty must have a powertrain
inspection performed by an authorized Chrysler, Dodge, or Jeep dealer once every 5 years. This inspection will be performed at no charge. The inspection
must be made within sixty (60) days of each 5 year anniversary of the in-service date of the vehicle. You must have the inspection performed to continue
this coverage.
H. Other Provisions of This Powertrain Limited Warranty
All other terms of the New Vehicle Limited Warranty including the Section 1 (Your Rights Under These Limited Warranties) and Section 3 (What’s Not
Covered) apply to this Powertrain Limited Warranty.
This document supplements the warranties and conditions described in the vehicle’s Warranty Information book.
No other coverages are altered or extended based on this supplement.
81-016-8057 Gas Vehicles
Old Aug 10, 2013 | 06:20 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
When the car is sold, your information is entered into the Chrysler database. The "In Service" will typically reflect the date of sale. Build date is something totally different and is not relative to the warranty.
A good dealer will typically not bonk you on your powertrain inspection unless there is just something so totally out in left field that it defies logic. Such as...you made a "Bigfoot" out of your truck.
If you have active DTCs in the powertrain system (engine or trans codes) they will usually have to be addressed before you get passed. Things like misfire codes, catalytic converter, coolant temp, EGR, that can cause engine damage when ignored, are the types of things you will (and should) stay on top of and may cause you to not get passed until you fix.
Old Aug 12, 2013 | 10:16 AM
RGVram99's Avatar
RGVram99
OK good to know. I read a comment on another forum stating that dealers are required to look for any modifications that could impact the powertrain. I can see how swapping internal drivetrain components (cam, torque converter, gears) might be frowned upon or showing up with a supercharger. But IMO external bolt on's that do not touch oil should not be an issue.
