2014 Service manual
Old Feb 17, 2015 | 10:25 PM
RamTN's Avatar
RamTN
Default 2014 Service manual
Anyone know where to purchase a copy of the Service Manual for a 2014 Ram 1500 2wd? I tried to get one at Tech Authority, but they say it doesn't work with a Mac computer. I find it hard to believe that a pdf file on CD won't work on a Mac, but I don't want to spend $137 to find out they were right.
Thanks for any help.
Travis
Old Feb 18, 2015 | 12:54 PM
oldjeep's Avatar
oldjeep
Time to get yourself a real computer If you want a factory service manual then you need to have a Windows PC with Internet Explorer. If they are still the same as the 2009 fsm then the manuals are more than just a PDF, it is really more of a website that runs off a CD - which loads a lot of xml and images and uses an old version of SVG viewer. Unfortunately the files are not organized or named in such a way that they would be easy to sort through manually without the front end.
As far as I know you cannot buy printed versions of the factory service manuals any more, but you could confirm with your dealer. Only other option would be to get the typical Haynes/Chiltons manuals, which are OK for general things but pretty inferior to the FSM.
