Let me introduce myself..
Old Oct 27, 2015 | 08:29 PM
Arctodus's Avatar
Arctodus
Originally Posted by 13ram1500
If he mounted it the same way I did then here's how. I popped that plastic insert in between the fog lights out. Then you will see 2 metal brackets one on each side connected to the frame. I drilled a hole in each one and bolted the light bar in. The one I got was 30"s long. You may can get away with a 32" I'm not sure. In all took me about a hour an a half to mount it and wire it up.
Awesome and thank you. Were you able to cut the plastic and re-use it?
Old Oct 28, 2015 | 01:29 AM
13ram1500's Avatar
13ram1500
If your talking about the plastic insert in between the fog lights that I took out then yes you can re use it. You don't have to cut it at all. It just pops out
