Tire Pressure monitor question
Old Dec 20, 2015 | 01:44 PM
HoytDude's Avatar
HoytDude
Default Tire Pressure monitor question
Received a message to service tire monitor system. Checking this, I found the left front pressure info is missing. The other three are indicating proper pressure. Other than replacing this $$$ sensor, is there something I can do to fix this? Checking the actual tire pressure shows the same 60 psi as the other front tire.
Thanks,
Old Dec 20, 2015 | 08:53 PM
pitbull24's Avatar
pitbull24
I would bet the sensor went bad.
I have no idea other than to replace it, sorry.
Old Dec 21, 2015 | 05:31 PM
HoytDude's Avatar
HoytDude
You're probably correct. I can't think of what else could be the problem. Time to research best (least expensive) solution.
Old Dec 26, 2015 | 12:18 PM
Duso02's Avatar
Duso02
Buy the sensor from Rockauto for $45 and have it changed for $20
Old Dec 28, 2015 | 08:57 PM
HoytDude's Avatar
HoytDude
Thinking because I have the extended warranty, simplest thing to do would be let the local dealer replace the sensor. Wrong! Turns out this warranty doesn't cover these sensors so after a four hour wait and $174.00 later I drove away with the <30 minute repair complete. Lesson learned.
Old Dec 28, 2015 | 09:35 PM
pitbull24's Avatar
pitbull24
yikes!
At least you got it fixed, and don't have to stare at the dummy light.
Old Jan 14, 2016 | 09:51 PM
rick4dak's Avatar
rick4dak
The guys at Discount Tire charge $60 each to replace the sensors.
