Looking for advise
Old May 9, 2017 | 03:06 PM
Drewamt's Avatar
Drewamt
Default Looking for advise
I have a 2017 1500 5.7 V8 3.21 gear ratio. I'm looking at purchasing a camper that's dry weight is 5800 pounds. Is this too much weight or will the truck do fine? Thanks for the input.
Old May 9, 2017 | 03:16 PM
Your owners manual will contain towing information for your particular vehicle.
Old Jun 4, 2017 | 06:46 PM
patchelect's Avatar
patchelect
I don't know specifically but there are many things I learned when I was thinking about towing with my Dakota. A dry weight of 5800 pounds can easily gain another 1000 pounds or more before you get rolling between all your stuff and a tank full of water. The 3.21 might give a problem because it is a longer gear and less load friendly than a numerically higher rear. You may get more information at RV.NET, although they have their own opinions that can help confuse!
But I will also agree that your owners manual should have guidance. Just don't forget that the trailer numbers are only a start! The "stuff" numbers are much more important. And remember that you and the family also adds to load numbers larger than you might imagine. And if you plan on bring a dog there's another added weight.
