ABS error
2014 1500 43,000 miles, new tries 4,000 miles
just got back from a 1,000 mile trip, but had an error showup intermittently on the evic
Sometimes when I first started up, OR sometimes while driving on 2 lane roads, I would get 2 error msgs... Service trailer brakes THEN Service ABS system, an ABS error lamp turned on, AND my cruise control would stop responding at the same time. I was never pulling a trailer when this happened.
Sometimes the error would be gone after being parked, sometimes not. The ONLY time the error EVER went away on it's own after NOT being parked was once, I started, got the error, and 10 seconds later peeled out of a loose gravel driveway slightly squacking the tires when I hit the pavement... error light turned off and all was normal after that.
this all happened in a 12 day time period. Yesterday I traveled about 275 miles pulling trailer without an incident and errors.
Anyone have any ideas?
I did find a STAR case that involved the ABS, but it does mention the following DTCs: "DTC’s, U0415- Implausible Data Received From ABS, C0037-1D Left Wheel Speed Sensor Current Out Of Range, U1412-00 Implausible Vehicle Speed Signal Received, may be active or stored."
Not sure if any of those popped up for you, but your Ram dealership would be able to take a look at case S1308000332 to see if it applies to your truck.
Kori
Ram Social Care Specialist
