Climate control panel problems in ‘11 Ram 1500
Old Feb 15, 2021 | 12:14 PM
BigRed11#'s Avatar
BigRed11#
Default Climate control panel problems in ‘11 Ram 1500
So the climate control panel is acting up? Only thing that is still controllable is the first **** on the left for fan power and speed. No control over cool / heat in the middle **** and no control over the **** on right that selects the function. When fan speed **** is turned up it sounds like only air blasting through the defrost vents. Can’t change temp and can’t turn to get air / heat to come through the vents on the dash. Also no lights lighting up the controls. Which fuses should be checked and if it’s not fuses what is the advise ? And is there still a Heating or Air control recall out there? It seems I saw there was one for a 2010 model that someone had. Please help . No heat fogged up windows when leaving for work every AM at 5am sucks ! Lol
