Removing the tailgate & bed trim
Old Mar 26, 2009 | 12:59 AM
bigred3297's Avatar
bigred3297
Actually it seems to be an easy fix to me. Take off all the trim pieces, weld plates to fill the holes, grind down your welds, and then take it in to get sprayed.. They will do the rest of the sanding.
Old Mar 26, 2009 | 08:25 AM
JINXR's Avatar
JINXR
anybody know how to take it off? is it taped in there or does it just snap on?
Old Mar 26, 2009 | 08:32 AM
bountyhunter's Avatar
bountyhunter
The rail trim just snaps in place. Use a fiber stick to pry it off. Post some picks when ya weld up the holes!
Old Mar 26, 2009 | 08:52 AM
Smoothbassman's Avatar
Smoothbassman
the tailgate trim just pops off. on mine.
I hear that they made some changes with a recall, you might want to take that back panel off of your truck tailgate to see if they put screws in there from the bottom that you can't see.
Old Mar 26, 2009 | 10:38 AM
lancelanz's Avatar
lancelanz
i just had mine replaced. the dealer had the bed sprayed before i bought it and the place they had it done at didnt put one of the clips back on and it kept popping up on one side so they replaced the whole thing.
i agree that you should weld the holes up. if you saw the pics of the tailgate then you saw how big the holes are. i dont know if the lining wouldnt cave in on the holes without welding them up first.
Old Mar 26, 2009 | 10:52 AM
Secret Agent Man's Avatar
Secret Agent Man
There are now screws holding the trim on. Later built trucks will have better retention though because they increased the size of the tabs for engagement when snapping it in. Early trucks it sometimes fell off on its own just with the wind. Later trucks you will need a fiber stick and a can of spinach...
