Gears in an 09?
Old Apr 12, 2009 | 07:28 PM
dpracing57's Avatar
dpracing57
Default Gears in an 09?
Can I change the rearend gears on an 09? Ratios available?
What about a programmer for the gear swap are they're any available yet?
I have a 4.7.
Thanks in advance guys.
Dominic
Old Apr 12, 2009 | 07:47 PM
sarguy01's Avatar
sarguy01
Gears? 3.21, 3.55, 3.92, 4.11, 4.56, etc.
I have no clue about a 4.7 programmer for an 09. The Hemi was changed so much it is not out yet.
Old Apr 12, 2009 | 09:00 PM
MinatorHemi8's Avatar
MinatorHemi8
no programmers out for any 09 chrysler products there barely getting out all of the 08's
Old Apr 12, 2009 | 09:38 PM
v8440's Avatar
v8440
No programmer needed for gear ratio changes needed, either, unless they've changed where they get the speed signal. My understanding is the sensor is in the rear axle centersection, reading off the tone wheel bolted to the carrier. This means that the speed reading won't notice a gear change-the only thing that will require altering the factory calibration on that is a tire height change.
Of course, I'm only saying no programmer needed to accomodate a gear change, I'm not saying no programmer needed for performance improvements...
Old Apr 12, 2009 | 10:43 PM
ShirtaDay.com's Avatar
ShirtaDay.com
Do a search. Lots of discussion on gears already on here.
No programmer needed for gear change. Lots of other reasons such as performance or tire size changes. No programmers out yet. The programmer for the Hemi will come out first. It may take another year or more for the 4.7 since demand is so much lower.
Old Apr 13, 2009 | 12:08 AM
dpracing57's Avatar
dpracing57
Thanks guys!
I assume the speedo and trans will operate as normal after the gear swap?
How about the drive shaft, will it need rebalancing w/ a 4.10 ratio?
Where can I get the gears and how do I know what rear I have? (Gears, housing size)
Old Apr 13, 2009 | 06:10 AM
sarguy01's Avatar
sarguy01
The rear is 9.25 and your window sticker will tell you what gears you have.
Old Apr 13, 2009 | 09:07 AM
dpracing57's Avatar
dpracing57
Thanks for the reply.
The window sticker does not indicate the ratio???
Old Apr 13, 2009 | 09:09 AM
sarguy01's Avatar
sarguy01
Yes it does. It should be a 3.21, 3.55, or the anti-spin 3.92.
What type of truck is it?
Old Apr 13, 2009 | 11:30 PM
dpracing57's Avatar
dpracing57
Its a 2009 4.7 quad. SLT 20" wheels.
I checked again, its does not say the ratio. My other 2 ram stickers from previous do!
Go figure.
Thanks.
