does anyone remove the overhead console?
Old Apr 23, 2009 | 11:28 PM
patpeoria's Avatar
patpeoria
Default does anyone remove the overhead console?
Wanted to plug my Valentine directly in the overhead console, does anyone know how to remove it, thanks
Old Apr 24, 2009 | 04:09 AM
cameron1507's Avatar
cameron1507
yea just use a small flat head and start on the back (away from windshield) and start pullin it out. in the middle there are two clips that feel tough but they will come free with a lil tug. let me know what wires you use. i wanna do the same but no luck so far
Old Apr 24, 2009 | 08:59 AM
patpeoria's Avatar
patpeoria
Ok, thanks, will try tonnight and let you know
Old Apr 27, 2009 | 04:18 PM
cameron1507
so any luck?
Old Apr 27, 2009 | 10:29 PM
patpeoria's Avatar
patpeoria
Oups, strange I hink i posted a small post Friday night but apparently i was not.
Sorry but went back late last friday and flew oversea for two weeks, so no chance to try, will take a look again when i will be back, curently the truck is waiting for me (I hope) at the Chicago long term parking... I miss it (jusy have it fro 3 days!)
Sorry again, but it's nice to stay in touch with you guys even from the midle of nowhere... or China!!!
Old Apr 28, 2009 | 11:49 AM
Smoothbassman's Avatar
Smoothbassman
Your right it just pops right out. Start at the back to pop the clips, and then it slides back to get the entire system out of the roof.
I used a multimeter and found a switched power lead that controls the rear power sliding window. I just tied into that circuit to power my radar detector, so it turns on and off with the truck. Since it was outputting exactly 12.5 volts with the truck running, I didn't even bother wiring in a fuse. Works perfectly.
Don't remember the wire colors, except that the ground was black. It's a quick job if you have the right tools.
Old May 11, 2009 | 06:16 PM
patpeoria's Avatar
patpeoria
I connected my V1 to the over head console.
As described before, you remove the overhead by pushing it forward.
I found the ground on the connector for the remote opener: Black wire
I found a “plus” after ignition on the rear window sliding button: the pink one
Very easy to find a way for the Valentine connector and there is plenty of room inside the panel for the extra wire.
Just a little bit difficult access for my big hand!
I try to post pictures but it did not work…(as a foreigner I might not understand the forum web thing…) will try again latter….
