MDS and 5w30 oil
The lubrication won't change, the oil is thinner and can travel and lubricate faster/quicker. Oils can be thinner now because engines run quieter and don't need the thicker oil quiet down the rotating assembly. Stick with the 5W-20. It's what people with 6-8 years of school deveolped and designed as optimum. If they thought there would be a wear problem at all, they wouldn't offer a lifetime warranty.
Engines run more efficiently with lighter weight oil, less resistance from the thickness.
Yes, it is CRITICAL. There are some naysayers that will post things like, "I run xxx oil in my MDS Hemi and it runs fine".
If the engineers say you need it, it is probably a good idea to use it. The lifters work on oil pressure and the lifters are what run MDS. If you use the wrong oil, MDS may not or will not function properly.
Trending Topics
