iPod Integration Harness - Which One?
Old May 12, 2009 | 07:23 PM
Ironsides's Avatar
Ironsides
Default iPod Integration Harness - Which One?
My truck came with uConnect phone from the factory, and an RES/RSC radio with Siruis Satellite.
The Mopar site is telling me that the right iPod Integration Harness is 82211263AC. I purchased that cable today, and hooked it up, but got nothing. The radio and bluetooth still function normally, but there doesn't seem to be any connection to the iPod. The iPod charges, so I know the connections are good, but it won't actually do anything.
I searched online, and found this
Part # 82210787AB - For use on models equipped with factory UConnect and 4th generation radios (RES, REQ and REN). Currently NOT compatible with RER MyGIG navigation radios."
Part # 82211263AB - For use on models equipped with Mopar accessory UConnect and 4th generation RES, REQ and REN radios. Currently NOT compatible with RER MyGIG navigation radios
But then I read that the 82210787 cable, which would seem to be the right one, has a different connector than the 82211263 cable, which plugged right in.
So can anyone tell me which is the right cable, and where it gets connected? Thanks.
Old May 12, 2009 | 08:19 PM
tmot35's Avatar
tmot35
The bad news is that last week I had the same issue and the dealership contacted chryslers, only to find out that at the present time there is no cable that will work. Apple says it's the radio's and Chryslers says it's apple, so until they figure it out your cable is prob worthless.
Old May 12, 2009 | 10:45 PM
Ironsides's Avatar
Ironsides
Pretty weak, but I appreciate the info.
There are some Chryslers that come with iPod cables stock, right? What kind of setup do they have?
Old May 13, 2009 | 12:24 AM
cpelton's Avatar
cpelton
I ordered a 82212000 cable to try with my REN radio but its backordered until july 3rd...
Old May 13, 2009 | 01:28 PM
KWhitelaw's Avatar
KWhitelaw
Just got my truck back from the dealer and they have installed it. Work order didn't have a part number as it was part of the deal when I bought the truck month and a half ago have just been waiting for it to come in and it was worth it so nice to have iPod out of sight in glove box and charged up. Can control from radio and most functions from steering wheel controls so am loving it on the 5 mins. drive back to work at lunch. Would highly recommend to anyone considering.
Old May 13, 2009 | 01:54 PM
drober30's Avatar
drober30
Can you call the dealer and have them look up the internal "owe" order that they use. Parts department should be able to cross reference it or it might have the part number on it. Parts had to order it and bill it out to the deal.
That would help us out. I have the MyGig with nav and would like to integrate the iPod
Old May 13, 2009 | 02:01 PM
Ironsides's Avatar
Ironsides
What head unit do you have?
Old May 13, 2009 | 02:04 PM
Ironsides's Avatar
Ironsides
If you have the MyGig with Navigation, you should just need part number 82211853
