Fender flare lifting...
Old May 17, 2009 | 12:06 AM
Ryan Albert's Avatar
Ryan Albert
Default Fender flare lifting...
For those with fender flares has anyone had problems with them lifting? I have the TRX4 so I do have them, the one rear on the driver side has about a 7 inch section that has lifted up from the truck. Looks like they are held on by adhesive so I doubt the fix will be too tough, but just curious if anyone has had this problem. I have had the truck for about a month and have not been off road. This will be the first time I will have to take to the dealer..
Old May 17, 2009 | 12:09 AM
c0mf0rt's Avatar
c0mf0rt
No problems here. Fingers crossed
Old May 17, 2009 | 12:34 AM
Sobomaster's Avatar
Sobomaster
I'd try to sticky tape it down. The dealer can be the devil.
Old May 17, 2009 | 10:29 AM
BensGhost's Avatar
BensGhost
I have noticed our flairs are not completely flush against the body around the edges. They are not coming off so I just assumed it was normal. I can push in on them and they go more against the body so it could become an issue at some point I suppose.
Old May 17, 2009 | 03:40 PM
Ryan Albert
Yeah well I can see they are not completley flush because there is like a foam adhesion used but in this one section it looks like even the foam has lifted.
Old May 17, 2009 | 04:21 PM
BubbaRadioNetwork's Avatar
BubbaRadioNetwork
If the tape has lifted I would take it to the dealer and let them fix it. I noticed mine didn't sit flush when the truck was new.
Old May 17, 2009 | 04:52 PM
bigred3297's Avatar
bigred3297
havent had a problem but i can tell they are held on there by double sided sticky foam
Comfort- your sig should say 35x12.50
Old May 17, 2009 | 05:14 PM
Ryan Albert
Oh yeah I will def take it to the dealer...
Old May 18, 2009 | 07:56 AM
buckarcher's Avatar
buckarcher
Don't know what you mean by lifted, aren't they held on by screws in the wheel well? The tape should only adhere the top of them to the truck. This is how even after market flares work.
They suck at keeping mud off the truck anyhow. I think I'm going to try these.
http://www.car-stuff.com/carparts/do...907026864.html
Old May 18, 2009 | 11:12 AM
bigkahuna1's Avatar
bigkahuna1
Took mine back to the dealer was falling off same side
