stock 20" wheel backspacing
Old May 18, 2009 | 10:45 PM
cpelton's Avatar
cpelton
Default stock 20" wheel backspacing
wondering if anyone knows the stock backspacing on the 20" wheels?
Old May 18, 2009 | 11:12 PM
switchblade906's Avatar
switchblade906
the offset is +20
Old May 18, 2009 | 11:52 PM
MMMMRice's Avatar
MMMMRice
its + 19.5 lol, 5.25" bs
Old May 19, 2009 | 01:13 AM
cpelton's Avatar
cpelton
Cool, thanks
Old May 19, 2009 | 01:00 PM
MOPWR2U's Avatar
MOPWR2U
Backspacing is actually 5.75"
Old May 19, 2009 | 01:08 PM
rjc799's Avatar
rjc799
Which is it?
Old May 19, 2009 | 10:44 PM
BigRaq's Avatar
BigRaq
I'm a noob at modding so, what is backspacing?
Old May 19, 2009 | 11:24 PM
MMMMRice's Avatar
MMMMRice
offset is actually 19.05mm I missread the wheel. explain how its 5.75
Old May 20, 2009 | 10:28 PM
MOPWR2U's Avatar
MOPWR2U
Well, you would think that a 10" wide wheel with a 0 offset would have 5" of backspacing, wouldn't you. Except that wheel width is measured from bead mounting surface to bead mounting surface, and backspacing is measured to the back edge of the wheel. A 10" wide wheel is actually about 11" wide, because of the distance from the bead area to the edge of the wheel is about 1/2", on each side. So you can't do the direct math going from wheel width and offset to come up with backspacing, or you will be wrong by that 1/2" difference in where the wheel width and backspacing measurements are taken.
I got my 5.75" measurement from measuring my Laramie 20" wheels with a tape measure with the tires dismounted from the wheels. Just lay a straight edge across the back of the wheel and measure straight down to the wheel mounting surface, and it looks like 5.75" to me. It may actually be a metric measurement that is within 1 to 2 mm of 5.75", but I just rounded it to the closest english measurement.
MOPWR2U
Old May 20, 2009 | 10:43 PM
MMMMRice's Avatar
MMMMRice
I stand corrected
