Drop In Filters
Old Aug 28, 2009 | 08:14 PM
sarguy01's Avatar
sarguy01
Originally Posted by chambers
This is my UOA w/ an open element true flow foam filter on my intake. The silicon number is what you want to look at for dirt contamination and it is a little higher than universal averages, but still fine. The report can also be seen here http://www.bobistheoilguy.com/forums...94#Post1579494 along w/ comments from other members on the site. Judging from this report and some others w/ foam filters I think they filter well enough as long as they are properly maintained, the foam is thick enough (about an 1" thick), and they are 2 stage foam like the true flow.
Your lab looks good.
I am going to get another sample after this oil change. I used conventional instead of synthetic this time.
Old Aug 28, 2009 | 10:40 PM
swampercx's Avatar
swampercx
any info on the amsoil dry filter such as where to buy would be appreciated thanks in advance
Old Aug 28, 2009 | 11:14 PM
chambers's Avatar
chambers
http://www.amsoil.com/catalog.aspx?code=EAA176-EA that is what they show for the 09 hemi as the filter. I recommend the AEM dryflow if you want a dry filter.
Old Aug 29, 2009 | 04:14 PM
DKCSAR's Avatar
DKCSAR
I put in an Airaid filter, no problems with it.
Old Aug 29, 2009 | 07:01 PM
Sobomaster's Avatar
Sobomaster
I vote for one of the lower maintenance filters....
