antenna upgrade
Old Aug 4, 2009 | 09:01 AM
War Horse's Avatar
War Horse
Default antenna upgrade
Has anyone upgraded their factory AM/FM radio antenna to anything smaller or better? On my last truck I swapped the antenna out for one I bought at Auto Zone. While it looked better, the reception wasn't that great compared to the stock one.
Old Aug 4, 2009 | 10:22 AM
Tankit's Avatar
Tankit
I picked up this bad boy for $13.99 and it works great!
http://cgi.ebay.com/ebaymotors/Black...Q5fAccessories
Old Aug 4, 2009 | 10:33 AM
seigell's Avatar
seigell
Is it the Antenna (admittedly a stodgy standard design), or the flimsy plastic base mount on the curve of the fender, that is the real frustration ??
With the massive expanse of windshield glass, and the near-standard addition of Sat Radio, why didn't the designers opt for a nearly invisible integrated windshield antenna ??
Old Aug 4, 2009 | 02:20 PM
jawsdc's Avatar
jawsdc
yes, the mount has to go. almost worth having it removed by the paint/body guys. under-hood antennae possibly? with all the other entertainment options i very rarely listen to broadcast radio anyways.
Old Aug 4, 2009 | 02:39 PM
Tankit's Avatar
Tankit
just curious you guys bring up flimsy plastic base mount "
have there been issues with it?
Old Aug 4, 2009 | 02:41 PM
War Horse's Avatar
War Horse
Yea, I definitely wish there was an internal antenna. The stock was is decent enough looking, but a little large for my tastes.
Thanks Tankit, I got one ordered and it's on the way.
Old Aug 4, 2009 | 07:04 PM
jaflowers's Avatar
jaflowers
Bought one of those also. While it looked great and had good reception it caused one problem for me, it WHISTLED from all speeds past 45-50 mph. On the interstate I had to crank the radio to get that whistle sound out of my head, could still hear it. I have the Mopar bug deflector, pulled that off cause I thought it might be making the noise..... no help. Took it to the dealer and felt like an idiot when they told me what was causing it. Thank God I saved the old one. Wish I could find a different one cause I hate the look of the big steel one, it is rusting here in Florida.
Old Aug 4, 2009 | 08:21 PM
War Horse's Avatar
War Horse
Wow, that is odd. I've not heard it yet, but it's probably one of those sounds that once you hear it, you'll never be able to un-hear it. Hopefully the new antenna will stop that, or at least reduce it quiet a bit.
Old Aug 4, 2009 | 11:53 PM
seigell's Avatar
seigell
Problems: Kind'a yes... Since the carwash guys remove the antenna every time, and then screw it back "un-tightly", I've had numerous experiences hopping out to tighten it before it falls off. And I've noticed that the plastic base is starting to be loose - rotates a bit on the fender under normal pressure. It won't be too long before that causes paint rub or rotates to the point of breaking the mounting - which is surely just a plastic plug...
Old Aug 5, 2009 | 10:03 AM
lb79theone's Avatar
lb79theone
From: Maine! ( GET A HOLD OF ME IF YOU WANT TO GET ME ON FACEBOOK.COM, AND CARDOMAIN.COM)
I got one off e bay that is 13" amd thicker and rubber! Looks good and I get better reception for my system!
