Plug Change
Old Oct 1, 2009 | 04:48 PM
  #21
Bobba Booey's Avatar
Bobba Booey
Has anyone had their plugs changed at the dealer? How much was it?
Old Oct 1, 2009 | 04:50 PM
  #22
sarguy01's Avatar
sarguy01
Originally Posted by 2006NightRunner
A spark plug is not voodoo science. If the spark plug is the correct heat range, and is gapped properly before installation, it should perform fine. The coating on the electrode just extends the life of the plug. I agree it may be cheaper to run copper plugs rather than platinum over the life of the vehicle, but I would rather spend a few more dollars and save my knuckles.
Adding metals changes the resistance of the spark plug. A slight change is all that is needed to have the PCM notice that something is different and throw a code. Dodge programmed the PCM to use a certain copper plug. Changing it could change voltages in the system, which is when codes appear.
Do some research on hemis and platinum plugs and you will see that they have caused problems.
Old Oct 1, 2009 | 07:20 PM
  #23
09 Ram TRX 4 Lover's Avatar
09 Ram TRX 4 Lover
I agree with you!! If a spark plug would cause a problem in any vehicle let alone the "HEMI" they would not be in business long. Thats just me though.
Old Oct 1, 2009 | 07:34 PM
  #24
sarguy01's Avatar
sarguy01
Everyone thinks that plugs cannot cause problems. The statement, "Its just a spark plug" is very ignorant. Really, search the internet and everyone will find where a little spark plug can be the cause of major problems.
http://www.jeepforum.com/forum/f67/p...-stall-705109/
I have a 07 Commander Limited with the 5.7L Hemi. I installed the Champion 3570 Platinum Plugs(that i bought at PEP Boys)and the car started to stall. I took the Jeep the the dealership explained to them what I had done and 30 days later and 3 different modules(PCM,FCM,WIN) replaced they blamed it on the spark plugs. They explained to me that the Hemi engine will not run properly with the Platinum Spark plugs only the original copper plugs. I am a ASE certified mechanic of 10 years and I have never heard of anything like this. All the mechanics at the dealership also have never heard of anything like this. It took an engineer form Detroit that they flew out to figure it out. Do any of you guys run Platinum Plugs? Have any of you heard of something like this.
Thanks for your guys Help
Here is one thread I found. I quoted the person who had problems. There are two people in that thread that ran platinums that have had the same problem.
All I am saying is that there is really no benefit to running platinum plugs other than the fact that they last longer. I don't want to see anybody post about some butt-dyno claim that platinum plugs gave them more hp. Plus, most people claim a gain of MPG and power after a spark plug change when they took out 30K mile old plugs. Sure, new plugs are always better than old ones!
Lastly, you will still pay around the same for platinum as you would for two to three sets of coppers.
Old Oct 1, 2009 | 07:36 PM
  #25
Islander_212's Avatar
Islander_212
I think the main reason for the short interval plug changes has to do with the aluminum heads and the potential for a plug to seize in the head. I believe there are other aluminum heads out there with longer intervals but am unsure as to what the differences are. My 2003 has the original plugs in it with over 100,000 miles and it runs fine and gets nearly 20 MPG. I guess I should change them!
Old Oct 1, 2009 | 07:50 PM
  #26
sarguy01's Avatar
sarguy01
Okay, did some more digging. It seems we have a wasted spark ignition system. With this type of ignition system, one spark plug is fired normally and the other is fired backwards.
With one firing backwards, if the plug is not a double platinum, it will wear prematurely and cause issues since the plug gap gets bigger and bigger.
So, I am thinking a double platinum *should* work while the single platinum will cause issues.
Old Oct 2, 2009 | 11:26 AM
  #27
John Valdes's Avatar
John Valdes
What did the engineer from Detroit have to say? Price of the plug to me is not as important as the labor cost to install them. $2 or $8 is not the issue. It's how long will this take and has anyone paid to have theirs changed. This is the question I asked to start the thread, yet I am getting a class on spark plugs. I don't care what they use. I only care what they charge. The dealer does ALL my maintenance. And I will not do anything to affect my warranty adversely.
Old Oct 2, 2009 | 11:56 AM
  #28
2006NightRunner's Avatar
2006NightRunner
I totally agree with you. I think alot of the issues people had with installing the store bought platinum spark plugs, is gap related. My Autolite double platinums were not even close to the factory gap. They ranged from .040"-.060". I regapped them all to the factory .045" before installation. I haven't had any issues so far and the truck gets the same gas mileage as before.
Old Oct 2, 2009 | 11:57 AM
  #29
frofro666's Avatar
frofro666
Originally Posted by savage_46
you have to contort your arms and work around it. i usually put one arm over valve cover to hold the extension, and the other arm under booster to turn the ratchet. its a little tricky breaking them loose--lots of pointy stuff back there to stab your hand on.
FWIW: those of you doing plugs yourself on the 5.7, i highly suggest getting a magnectic plug socket. its SO MUCH EASIER not having to deal w/ the old style sockets w/ the rubber boot. i save about 10-15 minutes per 5.7 tune up cause of this.
How hard is it to get the coil packs off?
Old Oct 2, 2009 | 01:05 PM
  #30
sking's Avatar
sking
I feel for you here. Some people know everything BUT the answer.
