Old Aug 10, 2015, 06:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
What is the correct tire pressure?
Old Oct 5, 2009 | 09:28 PM
Duso02's Avatar
Duso02
A tire manufacturer has no clue what vehicle their tire is being mounted on so they have no idea what the optimum pressure will be. That's why they only give you a maximum pressure that the tire can handle for a max possible load the tire can handle. Your tire will say inflate to 44 psi to carry (guessing) 4000 lbs. Well, add up all 4 tires and if your truck, cargo, and passengers add up to 16000 lbs. by all means, run 44 psi!!! That will accomplish nothing but give you a stiff ride.
Google it, every (professional) tire maker, (professinal) car maker, (professional) consumer site, (professional) tire mechanic, etc. will say the same thing.
Old Oct 6, 2009 | 07:34 AM
Dodge12345's Avatar
Dodge12345
Dodge says 35psi is best then run with it. Higher or lower then recommended will cause the vehicle to preform different, rough ride, poor fuel economy, harder to handle in wet weather etc. Personally if I am going on a long highway trip then I will run a couple psi higher say 37. If winter and doing a lot of snow driving I will run a couple psi lower then recommended say 32-33psi for better grip.
Old Oct 6, 2009 | 09:20 AM
spoon's Avatar
spoon
Running my 20's at 40psi and happy with both wear and mpg improvement
Old Oct 6, 2009 | 11:23 AM
BOFslime's Avatar
BOFslime
I always thought the recommended was on the low side for the 20's, and I have also been running at 40psi without issue. I tend not to slow down to grandma speeds for corners, and the recommended rolled over too much. Been fine with 40psi, with no signs of center wear.
Old Oct 6, 2009 | 12:15 PM
Beverly Stayart's Avatar
Beverly Stayart
Thanks for sharing this helpful info.
