Tire Rub ?? Should be easy
Old Oct 8, 2009 | 10:33 PM
  #21
oldjeep's Avatar
oldjeep
Originally Posted by jayman84
I have never heard of the tire pressure system warning you about too much pressure. my buddy upgraded tires on his ford and went from a passenger tire to a light truck tire and started running 60 pounds in his tires which was up from the 35 punds stock and his light doesn't warn him about his tires having too much air in them.
According to the manual it doesn't - which is the opposite of what I've experienced. Trip down to lake of the ozarks, 85 MPH on a good hot day and my Pressure light came on. Pulled over and checked the tires which were all above 40 and very warm. Assumed it was because the TPMS was also measuring overpressure - maybe just another glitch, but it's the only time the light has ever come on for me.
Old Oct 9, 2009 | 07:51 AM
  #22
09 Ram TRX 4 Lover's Avatar
09 Ram TRX 4 Lover
Originally Posted by oldjeep
What do the sidewalls of your tires say is acceptable pressure range? Not all LT's are going to want 50 PSI - but the ones the OP is looking at do.
I just looked this morning and surprising to me it said inflat per owners manual or door sticker. The only other pressuse that was on the the tire was for different load's (weight) at 65 psi.
Old Oct 9, 2009 | 01:57 PM
  #23
oldjeep's Avatar
oldjeep
Yup. And the door sticker is not valid any more since you changed the type of tire/load rating. The tire you put on is designed to run at a higher pressure - might want to keep an eye on tire wear if you are running them at 35. Chances are good that they will cup at that PSI.
