installed 2.5 leveling kit noticed a bad shake in stering
Old Oct 11, 2009 | 06:20 PM
coonasscummins's Avatar
coonasscummins
Default installed 2.5 leveling kit noticed a bad shake in stering
i installed a 2.5 leveliing kit on my 2009 ram 1500 sport and now have a real bad shake from 65 mph and above ?????????? help i didnt do and allignment for the fact that if i have to take the kit off id have to reallign again ........anybody no what may be causing this
Old Oct 11, 2009 | 06:59 PM
jason2922's Avatar
jason2922
what kit did you buy?
Old Oct 11, 2009 | 07:18 PM
jake09's Avatar
jake09
Your alignment is off or wheels are not balanced correctly...but it is probably the alignment
Old Oct 11, 2009 | 07:20 PM
jake09's Avatar
jake09
Your alignment is off or your tires are not balanced correctly but it is probably your alignment....mine shook after the level kit but stopped after the alignment was done
Old Oct 11, 2009 | 08:16 PM
sking's Avatar
sking
What kit do you have? I took my truck up to 90 mph yesterday and started to shake a slight bit so I let off the gas and had the death wobble. It was so bad the truck pulled 3 lanes and I ended up in the grass. My Daystar kit is coming off in the morning then I will have the truck aligned again. Once its all back to stock I will try the 90mph again to see if its ok without the kit. Before I put the kit on, I had it up to 98 once with no problem.
Old Oct 11, 2009 | 09:36 PM
switchblade906's Avatar
switchblade906
Any time you lift or lower a vehicle or change the tire size you have to get an alignment
Old Oct 11, 2009 | 10:22 PM
coonasscummins
thanks guys for your help i will get and allignment done tommorow and hope for the best
