P265 70R-17, stock tires, what pressure?
Old Oct 13, 2009 | 10:05 AM
Scott2009Ram's Avatar
Scott2009Ram
Default P265 70R-17, stock tires, what pressure?
I live in the Houston area and when the temps went from highs in the 90s to highs in the 70s, my tire pressure dash light came on.
I thought it would go away when the tires warmed up, but no luck.
So I check the pressure and they were all at 35 psi.
The tire is marked for max. psi of 44.
What pressure to you run in your tires?
Thanks,
Scott
Old Oct 13, 2009 | 11:49 AM
kasjun's Avatar
kasjun
If they are the stock tires the tire pressure will be on the sticker inside the drivers door.
kasjun
Old Oct 13, 2009 | 07:34 PM
Duso02's Avatar
Duso02
If you adjust the pressure to the sticker when cold and light still comes on, bring it in, because it really should only come on when an significantly lower pressure is sensed.
