Mufflex quality?
Old Oct 14, 2009 | 05:11 PM
CarGuyOhio's Avatar
CarGuyOhio
LOL, I know mine is not loose, I put it on and there is no black buildup around the seems.
Old Oct 14, 2009 | 06:13 PM
Lightning04's Avatar
Lightning04
Installed mine about two months ago, Lvoe the sound and was easy to install. No problems at all. I did have an impact gun tho
Steve
Old Oct 14, 2009 | 07:01 PM
daprincipal's Avatar
daprincipal
I broke the first bolt off today taking off the stock muffler and said $^% it. I took to a local muffler shop and they took off the stock muff and put on the 24" for $50 bucks since they didn't have any business. They said it bolted right in. Sounds great!
Old Oct 14, 2009 | 07:55 PM
Oosik's Avatar
Oosik
Originally Posted by 94rt10ohio
I mention this (clamp position) in my DIY. The other thing, if you do not have an impact (electric or air) you will have a VERY hard time getting it tight. You would be amazed at the difference between using a wrench and using an impact.
The ironic thing about this whole thing is, if they used a lower "quaility" pipe (smaller gauge) it would clamp down easier, but then you have a inferior product.
https://dodgeforum.com/forum/diy-do-...4rt10ohio.html
I can't open the pictures here...any idea why?
Old Oct 15, 2009 | 04:08 PM
topgun's Avatar
topgun
It's not you. They have been that way all along.
Old Oct 17, 2009 | 06:26 PM
danno5069's Avatar
danno5069
Default mufflex
Was going to have welded but called mufflex instead, appears they sent 2 1/2 inch instead of 2 1/4. Could have saved a lot of grief if kid making them was paying attention. Will keep myou posted.
Old Oct 17, 2009 | 08:17 PM
CarGuyOhio's Avatar
CarGuyOhio
I have no idea, always show when I am in the post. I removed and re-added, try again.
Old Oct 18, 2009 | 09:34 AM
topgun's Avatar
topgun
The pictures do not work. Never have since I have been a member here as I looked to view them long ago. Here's what it says:
you do not have permission to access this page. This could be due to one of several reasons:
1: Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
2: If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Old Oct 18, 2009 | 01:37 PM
CarGuyOhio's Avatar
CarGuyOhio
Given it would take WAY to long to get support to look at this I just inserted the pics as embedded images so you should be able to see them now.
Old Oct 19, 2009 | 04:12 PM
topgun's Avatar
topgun
That's better! Thanks!
