HIDxtra Website Questions
Old Oct 22, 2009 | 10:31 PM
WESIDE's Avatar
WESIDE
Default HIDxtra Website Questions
Does this web site have a good reputation for quality and all? I just heard about them. I am looking into getting a set for the low and fog lights. Some pics would be awesome for a before and after. Are there any other companys out there making a similar hid that I should look into? I was considering going with the 8000k on the lows and the 3000k on the fogs to give it a little more of a realistic fog light look. Anybody have an opinion on that or pics? I think it looks good with matching colors but it does take away from the fog light output. OPINIONS PLEASE! Also I did not see an option for the purchase of the 9145 bulbs. Thanks, Wes
"FYI Owners manual"
low beam H11
Fogs 9145
Old Oct 22, 2009 | 11:00 PM
jason2922's Avatar
jason2922
8K will be a blue/purple and 3K is ok... I'd rather do 6K for both, but that's me. Seems like you want that blue/purple look and functional fogs, seems fine to me. If i was doing 8K, i'd do 6K fogs... to me, there would be more of a blend and not two distinct colors. it's all about the look that you want to make you diff from others, go with what you like if you're going to spend the cash.
Old Oct 23, 2009 | 12:01 AM
shep8235's Avatar
shep8235
I just got a set for my ram..I got the 600k for my lows and fogs..The only problem that I has was they sent me the wrong harness. But I called them and they said that I should have gotten the capacitors instead of the relay harness. They sent me another one with no problem and I got it within 2 days. I really like the way look and they are super bright. I would definetly recommend them. Besides, for $120 for 2 kits, can't beat that...If you are going to get some you might wanna get the same colors. To me, 2 different color bulbs look funny and trust me, the 6000k is definetly the brightest. If you have the 09 ram, the your low beams are H11 and the fogs are H10..Just make sure that you get the capacitors for the low beams. You don't need the capacitors for the fogs...Hope that this helps you bro...
Old Oct 23, 2009 | 12:15 AM
WESIDE's Avatar
WESIDE
Im glad you replied Shep. I saw your original help post and was interested in the setup. The manual says the fogs are 9145? are those the same as h10's? I also am wonderiing if you had any pics of the lights installed on your truck? I have seen some pics with the same color lows and fogs but was wondering what yellow fogs and blue lows would look like? any opinion? Thanks Wes
Old Oct 23, 2009 | 01:59 PM
shep8235's Avatar
shep8235
The 9145 are the H10s..I am sure that the yellow will look fine, but I like to have all the lights match..Plus the 6000k are just so much brighter then the other ones...I would post some pics but my camera is dead and I can't find the charger..I will try and get some for you some how..
