Knocking sound when accelerating - Solution
Old Nov 13, 2009 | 03:28 AM
cpelton's Avatar
cpelton
Default Knocking sound when accelerating - Solution
In the past couple days a knocking noise developed which could be felt through the floor of the truck. It made noise on the initial weight shift of the truck when accelerating or decelerating. I found it to be one of the rear links, the bolt which attaches it to the frame was slightly loose. Just a heads up if anyone hears this noise, I read somewhere of a similar issue.
Old Nov 13, 2009 | 11:12 AM
AZdave's Avatar
AZdave
Did you throw some thread locker on it or just crank-down on it?
Old Nov 13, 2009 | 01:25 PM
Secret Agent Man's Avatar
Secret Agent Man
What rear link? Sometimes I hear a light clunk, but not every time and its usually faint. Also, how many miles on your truck before it developed this symptom?
Old Nov 13, 2009 | 02:55 PM
cpelton's Avatar
cpelton
It happened to be the lower right hand although it could happen to any of them. That is probably what it is as mine was faint as well and not all the time, small noises like that drive me off the edge until I find out what it is.
Try having someone jump on the rear bumper - this duplicated the noise for me and put your hand on each of the links, you will feel a clunk if one is loose. It wasn't dangerously loose, it took a wrench to turn the bolt but I think it lost its clamp on the rubber bushing and the noise was coming from the bushing moving. I have 20,000km now but I also had the whole suspension apart to install the lift at 10,000km. I did install all hardware with blue loctite and torqued to spec.
