Shake in 4 wheel drive
Old Nov 15, 2009 | 04:36 PM
JohnVI's Avatar
JohnVI
Default Shake in 4 wheel drive
Hey gang
Sorry if this was posted, i did perform a search and didnt see it..
This is my first truck, so im guessing you pro's will say "Yeah that normal"
I just noticed when i put the TRX in 4 wheel drive (4 wheel lock) driving in the rin the other day roads were very slippery and the back end was everywhere (maybe i jut need BFG AT/TA or Duratracks) i noticed the truck shutters in 4 wheel drive??? is this normal ? Its was weird, but the truck kind of vibrated a bit..... tough to describe, but it might be a normal thing for trucks in 4wheel drive
Old Nov 15, 2009 | 04:43 PM
Hahns5.2's Avatar
Hahns5.2
4wd is not for use on pavement unless that pavement happens to be covered in snow/ice! The front and rear axles cannot turn at different speeds in 4wd, so things will bind on high traction surfaces.
4WD is not the same as AWD.
Old Nov 15, 2009 | 04:51 PM
sking's Avatar
sking
never mind, I just saw you started two threads for about the same thing.
