Bluetooth hookup for RES
Old Nov 27, 2009 | 08:57 AM
Rocknfire's Avatar
Rocknfire
Default Bluetooth hookup for RES
Hello Everyone~I have a 09 Ram with the RES radio and want to link my Blackberry through the Bluetooth function on my radio.
Do I need a kit to do this? When I push the Uconnect button or the little Bluetooth button it just says uconnect not available or something like that.
Any help would be appreciated.(I have a buddy who just got a Tundra, and his works without any add ons. I can't let him go around thinking his truck is better than mine.)
Thanks,
Doug
Old Nov 27, 2009 | 09:13 AM
tmot35's Avatar
tmot35
Unfurtunatly you will need the add on. I'm not 100% sure but I believe the box is mounted on the passenger side front fender. remove glove box and look to the right and up a bit.
Old Nov 27, 2009 | 09:35 AM
topgun's Avatar
topgun
You have to buy the kit to have Bluetooth functionality. It was an option when the truck was ordered. Looking under the dash, you will not find anything as you have to install the box. Go to Mopar accessories and you can see the kit, even look at the install instructions. You can buy it online for about $200.
If your buddy nags you, just remind him that your truck was cheaper and that this was an option.
Old Nov 27, 2009 | 10:11 AM
72combo's Avatar
72combo
It is 257, easy to install but must be starscanned by the dealer after, now it is a half hour charge but it took 14 hours and 2 dealerships to get mine to work. It was their problem, not knowing how to following directions on the starscan I suspect LOL>
Old Nov 27, 2009 | 02:36 PM
kxwhite's Avatar
kxwhite
do you guys know the part number for the bluetooth add on?
Old Nov 27, 2009 | 05:22 PM
72combo's Avatar
72combo
You will have to call the dealer give them your vin to get the right one for you.
Old Nov 27, 2009 | 05:45 PM
topgun's Avatar
topgun
Originally Posted by 72combo
It is 257,
Only a few bucks over $200 online as I mentioned. $257 is list.
Old Nov 27, 2009 | 10:38 PM
GapRunr's Avatar
GapRunr
Originally Posted by Rocknfire
I have a 09 Ram with the RES radio.......When I push the Uconnect button or the little Bluetooth button ....
I have the RES radio as well, but mine didn't come with the uConnect button. Does your head unit actually say RES in the bottom right corner?
Old Nov 28, 2009 | 08:58 AM
topgun's Avatar
topgun
There are 2 versions of the RES radio. If you don't have the RES with the Sat receiver, then you don't have the button and require a different upgrade which is more expensive.
Old Nov 30, 2009 | 05:57 PM
72combo's Avatar
72combo
The one you need will come with a remote button that you can stick to the dash or whereever the instruction say. It does have a wire attached so you might be limited. Good luck.
