dumb question
Old Nov 27, 2009 | 04:45 PM
Dodgeracing07's Avatar
Dodgeracing07
Default dumb question
ok i just picked up my 2010 Crew Cab today. I have a factory nav radio from a previous car. I want to swap it into my truck. i know i need to get it scanned at the dealer to activate it. so here is the dumb question, i have the bucket seats and i would like to know how to access the radio that is in there to remove it. i cant figure out how to pop off the face plate to gain access to it. a link would be great if there are step by step instructions. thanks in advanced
Old Nov 27, 2009 | 05:10 PM
72combo's Avatar
72combo
Default Not sure how to do this
You should find what you need here http://mofv.com/mygig/Documents/MyGI...structions.pdf
If anyone using these instructions to remove or install especially a REN radio be sure to remove the radio fuse before hooking up or removing the battery cable you can cause damage to the REN if you don't . This is an actual Chrysler TSB or Warning
Old Nov 27, 2009 | 07:05 PM
Bboyg's Avatar
Bboyg
Congrats on your new truck. You might want to make sure the radio you have will work in your new Ram. I know there are high speed and low speed BUS units and I don't believe they are interchangeable.
