tires with lift
Old Dec 30, 2009 | 06:05 PM
countryboy502ss's Avatar
countryboy502ss
Default tires with lift
ok I have done research, but I still cant get any straight answers. I have a set of 35x12.5r17 tires that I want to run on my 09 dodge. I am going to buy a new set of rims that are clost to the stock offset. Can this be done with out a lift?? or do I need a 2.5 daystar lift kit?? and what is the downside to the daystar kit??
Old Dec 30, 2009 | 06:41 PM
turk1270's Avatar
turk1270
if you have the trx which i believe sits a little higher they will fit and rub some at full lock other models they will fit but rub a little on full lock and be a little close to the wheelwell i would just add a 2" level kit for some extra clearance
