Oil change
Old Jan 3, 2010 | 05:05 PM
2010sltsprt's Avatar
2010sltsprt
Cool Oil change
Hi everyone, i was just wondering i have 3111kms on my 2010 dodge ram sport, im just wondering when the oil change light usually comes on. mine isnt on yet but i kinda wanna know when it will be on thanks for the input Anthony.
Old Jan 3, 2010 | 05:26 PM
RTCarlin's Avatar
RTCarlin
I just had the light come on for me in a 2010 SLT 5.7 at 2500 mi (4000 km)... There's a lot of debate on what the frequency for oil changes the computer thinks you should do... some have reported the light at 2500 then again at 5k...
IMO, I think the first change should be done when you get your first message, then routinely based on your beliefs (every 3k or 5k or whatever)....
Old Jan 3, 2010 | 07:05 PM
godster's Avatar
godster
Fuuny, mine just went on recently, I have about 9000kms on it.
Dario
Old Jan 3, 2010 | 07:36 PM
Pedro Dog's Avatar
Pedro Dog
Default first oil change 2009 Hemi Ram
Mine came on at 2532 miles. I had a hell of a time getting the filter off - it was really tight. You may want to get the first change done by a shop or the dealer. I punctured the oil filter with the removal tool and for a while I thought I would have to have it towed to the dealer. I was very unhappy so I persisted and finally got it off. I don't know if this is normal for the rest of the changes but for the first time, I was glad it finally came on as I did not want to keep running the "break in oil" longer than needed.
Old Jan 3, 2010 | 08:46 PM
RTCarlin's Avatar
RTCarlin
Mine was on pretty tight too... my filter wrench for my old Chevy fit the filter perfect... I put a 1/2 ratchet to it along with a 1" or so extension and, with a little encouragement, it broke loose.... The filter is in an awkward place with all the suspension components there....
Old Jan 4, 2010 | 12:20 AM
vmann's Avatar
vmann
The oil change indicator comes on based on how the vehicle was driven and the operating temperature. I work at a dodge dealership and the factory installed filters are always a major PITA.
Also: to reset the light turn the key to the on position (acc mode, vehicle not on) and press the gas pedal three times to the floor, turn the key off and then back on (vehicle on)
may take a few times to work
Old Jan 4, 2010 | 12:29 AM
2010sltsprt
Right on everyone thanks for the replies, im not sure on a new vehicle when i should change it do they use break in oil from the factory, thanks Anthony.
Old Jan 5, 2010 | 09:50 AM
jonthefireman's Avatar
jonthefireman
Ditto on all. I changed my "break in" oil at 1000, also had to literally pry my filter off with every ounce of strength I had. The EVIC message still appeared around 2500, I just reset it. I will continue to change about every 4000k.
