sub and amp install
Old Jan 16, 2010 | 07:52 PM
bigram00's Avatar
bigram00
Default sub and amp install
today i was helping my buddy put a sub and amp in his 2009 ram and we are putting it in on the stock head unit and we got everything wired up and whent to test and we had no remote power. i'm ask where did ya put your remote wire to?
Old Jan 17, 2010 | 07:06 AM
devile's Avatar
devile
You could find a acc power in the fuse panel, or tap it into the cig lighter, or get a lockpik...
Old Jan 17, 2010 | 10:50 AM
Eternalodyssey's Avatar
Eternalodyssey
I would stay away from tapping the fuse panel if at all possible because it is more involving & stick with the suggestion for tapping the cig lighter outlet. You won't be drawing much power so no need to worry about overvoltage.
Old Jan 17, 2010 | 01:07 PM
boutit600rr's Avatar
boutit600rr
I used the Cig. lighter and it worked great.
Old Apr 2, 2010 | 10:36 AM
edelsite's Avatar
edelsite
When you're done with the install, do you think you could post some pics of the install?
Old Apr 2, 2010 | 01:01 PM
Laramie1997's Avatar
Laramie1997
Never post to the fuse panel or cig lighter. Find a wire to tap into at the back of the radio. You want your amps to turn OFF when the radio is turned off. You really don't want to start wiring that amp's remote wire up to places other than a wire coming off of the H/U.
Old Apr 2, 2010 | 03:49 PM
CaliAthlete's Avatar
CaliAthlete
+1 for Laramie1997. Not good to have stuff constantly on when it doesn't need to be.
