Sonnax line pressure booster
Old Jan 21, 2010 | 02:34 PM
70GS455's Avatar
70GS455
Default Sonnax line pressure booster
Has anyone seen this transmission line pressure booster from Sonnax?
http://www.sonnax.com/announcements/44957-LB1_LB2.pdf
Is plug-n-play, external, and givse more torque capacity through more clutch apply pressure.
It's $39.95 here:
http://www.transmissionpartsusa.com/...rts_s/1456.htm
Old Jan 21, 2010 | 07:27 PM
MGH's Avatar
MGH
Put one on my truck 2 months ago.
Old Jan 21, 2010 | 07:55 PM
c0mf0rt's Avatar
c0mf0rt
Looks easy and cheap... forgive my ignorance but why??
Old Jan 21, 2010 | 07:57 PM
72combo's Avatar
72combo
I am an underexperienced transmission guy also, what will this do?
Old Jan 21, 2010 | 09:33 PM
jayman84's Avatar
jayman84
Basically it increases the line pressures in your transmission so that it will shift harder so there is less slip in the trans between gears which is supposed to help the trans run cooler. This is a good product to make your truck more fun to drive but if you already have the tow/haul button then I'm not sure why you need it.
Old Jan 1, 2012 | 02:35 PM
72combo's Avatar
72combo
So the Tow/Haul button is doing the same thing as this jumper?
Old Jan 1, 2012 | 08:01 PM
Pedro Dog's Avatar
Pedro Dog
https://dodgeforum.com/forum/4th-gen...-i-got-it.html
Additional discussion not long ago
Old Jan 2, 2012 | 10:59 AM
LU229's Avatar
LU229
Jayman84,
I dont think the tow haul button increase`s line pressure. (????)
I believe all T/H button does is change the shift program.
